Workflow from finished design backwards to manufacturing the parts
I'm not a professional ME so bear with me.
When I design a 'machine' I work from concept to the final functional design. But then I need get the parts made so how am I expected to go about that?
For example I design some part that has all the final dimensions but I want to get it cast so I need to produce the 'as cast' part and drawings.
When I start the 'machine' design I have very little idea how a part will actually me produced and even if I did I would have to / want to design the part 'as machined' and without regards to the cast dimensions etc.
What would be a good workflow?
Onshape, Inc.
Outside of working in Onshape there is a lot to be considered depending on the manufacturing process. If you want to dive deep into this a good starting point is with Dragon Innovations DFM course which goes through what to consider for several manufacturing processes: http://blog.dragoninnovation.com/category/design-for-manufacturing-course/
Twitter: @bradleysauln
My needs are mostly related to my spare time activities designing model engineering stuff where I usually start my designs from the functional/requirement view point with little consideration on how I'm actually going to produce the parts. In model engineering one often has the choice of either casting or simulating castings with other fabrication methods and this where my question stemmed from and to me it looks like branching is something I will try.
But having said that also 'at work' I see that we often design the 'machines' with little regard to how they are manufactured and then we design the parts for manufacturing often starting with say machining from billets and later converting to castings as we grow more confident that the design is good and the product volumes are there.
So my amateurism aside I think this is an important workflow question for pros too.
Thanks again.
