Revolve problem
mischl
mischl Member Posts: 28 ✭✭
hi there
is anyone able to see why this is going wrong?
my only hint is that if I choose add, these deviations are visible between the two parts, looking that not both have the same arc resolution.  perhaps it is only a render problem...
document: https://cad.onshape.com/documents/6be47f5f723c794b41ebf8d5/w/ea3952b761510d13651a6397/e/0c912ba664c080be611127a3
thanks in advance
    Just a tessellation issue. Right click the part and select edit appearance. You can then increase the tessellation value. Note that this is done for performance reasons and the geometry is in fact correct.
  • mischl
    thank you for your saturday work and the rendering issue.
    but it does not help to do the revolve properly to merge with the other part (part 1)
  • mischl
    thx, that made it
