Is it possible to limit the BoundingType enum options for an extrude?
Aaron_Hoover
Aaron_Hoover Member Posts: 35 EDU
One joint I'm working on is essentially a miter with a double dovetail or butterfly key that holds it together. The key is extruded and Boolean subtracted from the two parts that form the miter corner. I'd like to limit the extrude options to just 'Blind' and "Up to Face' ('Up to Next' is doing a weird thing where only half of the key, on one side of the miter joint gets extruded.) I'd like to limit the dropdown in the UI to only include those two options. Is there an easy way to do this?
