Offset of spline curve
D8_StarpacD8_Starpac Member Posts: 49 ✭✭
Offsetting of spline curve can't be done
    A 2D sketch spline or a 3D curve spline? Sketch spline should work fine. For 3D spline, the offset direction cannot be determined. If you are trying to offset a 3D spline in a 2D sketch, copy the spline into the sketch first (using “use”) then offset that.
  • D8_StarpacD8_Starpac Member Posts: 49 ✭✭
    Thank you for your help
