Pipe feature
andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
We've had requests for a pipe feature, so you can avoid the current create plane --> create profile sketch --> sweep workflow.
Thanks to @ilya_baran and the wonders of FeatureScript, here is a custom feature for pipes.
https://cad.onshape.com/documents/153cc3c8228c34a47f0b88d5/v/584ae1f362b4922e7cec3fe2/e/56f7232dfddc387a4c9e3f9c
Just select the path from edges or sketches and set the OD and ID.
Andy Morris / Head of Product Design / Onshape, Inc.
    That's really rather good, and presumably will rebuild just fine if upstream dimensions are changed, just as long as ID's stay the same?
    OwS
    HWM-Water Ltd
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    Yes, its just like any other Onshape feature in that regards.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,253 image
    The latest version (V4) has been updated to also support disjoint straight pipe segments with mate connectors.
  • colemancoleman OS Professional Posts: 244 ✭✭✭
    @andy_morris
    If feature scripts are so easy....why don't you guys just make this (and others) standard functionality?
    If every custom feature we wrote was added to the standard library, it would be a big polluted mess!
    A good place to say "thank you" for making featurescript so close to the user that we can make "mess" for ourselves. No any other CAD that has scripting environment in a list of standart invironment types on the first page of the project.
    edited December 2018
    @ilya_baran
    @andy_morris
    @Jake_Rosenfeld
    Here is a pipe feature that works with multiple paths in the one feature (I created my own constructPaths feature)
    https://cad.onshape.com/documents/e89f406ea0fb1b1a9225a055
    PS: Thank you for FeatureScript, otherwise none of this would be possible :)
    IR for AS/NZS 1100
  • Tony_C_Tony_C_ Member Posts: 280 PRO
    Cool.  Now can you make it put in all the fittings too?  ;)
    Great stuff @mbartlett21 !
    @Tony_C_
    Can you give an example? :)
    IR for AS/NZS 1100
    IR for AS/NZS 1100
    I have just made the constructPaths library public (I didn't realise it was private)
    https://cad.onshape.com/documents/3021561771935e716a44c1b1
    IR for AS/NZS 1100
    @mbartlett21
    Very cool!
    Botanist cool?
    HWM-Water Ltd
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 467 PRO
    The pipe feature is really nice!
    You can use it to make compression springs based on helix features:
    IR for AS/NZS 1100
  • wout_theelen541wout_theelen541 Member, csevp Posts: 198 PRO
    I just took a look at the FS there's an error generating the pipe in your example part studio
  • robert_barber444robert_barber444 Member Posts: 2
    Is there a way to use this feature with a tapered and bent pipe? I am trying to model a pipe that is 1" on the left end, has a slight bend, and smoothly tapers out to 2" at the right end
