Realistic Display and Rendering??
christopher_owens
Member Posts: 235 ✭✭
Hello! I have a project to model a replica of a concept building of which the customer wants images. I have used SolidWorks PhotoWorks before, and I am just wondering with Onshape(BETA) how could I get close to "Realistic Display and Rendering"??? Or is there a way to "Export to PNG" ??
You could always export out the cad and import it into another program. Lagoa is cloud based and free for some things.6
You can also 'export to png' by choosing Print from hamburger menu and RMB on preview and choose Save image. Quality is a bit better than taking a screenshot, but if you have HD screen - screenshots print out pretty nice too.
But if you need professional rendering then you will need to go through some actual renderer like Lagoa in cloud or installed software such as Keyshot.//rami5 -
Look at program Lightshot, it will replace your screenshot button with much better tool (select area, save to file, comment, etc..)
And if you don't have windows, you can still use Lightshot installed in your browsers..//rami0
"Hamburger menu"... like it! I did the RMB - Save Image on the preview and it worked great! I think for sharing a "rough draft" image of the model with the customer this works great! I did use the PrtScrn - Paste into Paint - Crop - Save method to share images on LinkedIn and a colleague before...this is much faster! Thanks!0
And if you don't have windows, you can still use Lightshot installed in your browsers..//rami0 -
I did learn by "why not try it Clicking" that I can go through my available printer options and save a PDF to my Google Drive! Keeps the file in the "cloud"!0
