Sketching on New Plane
geoff_joseygeoff_josey Member Posts: 67 ✭✭
I have a rectangular block with two holes thro the block. The original rectangle was on the top plane.
I now want to create 2 cut outs centered on each hole. When viewed from the bottom I create a new sketch, but when drawing lines to the outside of the block (rectangle as in original sketch which was used for the extrusion) There does not seem to be a line to meet. When you extrude is the new edge not created ?
Sensor Mount X Axis
https://cad.onshape.com/documents?resourceType=filter&nodeId=1
