Sheet Metal Conical Section
kent_hendersonkent_henderson Member Posts: 70 PRO
Take a look at the 2 furthest to the right parts studios called "Electrode drip chute 3 on 3" and "Electrode drip chute 3 on 4.75". I attacked both of these the same way but I can't convert the 3 on 4.75 to a sheet metal part. Any ideas?
https://cad.onshape.com/documents/d27682d4069e63fc26352d83/w/d17cc0f942eadeb4311929d9/e/e2b87ca9ad40ac1d15b249be
  • kent_hendersonkent_henderson Member Posts: 70 PRO
    I see that each of the facets now have the very slightest twist to each except the middle facet. So I see why I can't turn this into sheet metal. Any ideas on a work around? I'm old and can still layout by hand or with 2D cad if I have to. I'd sure like to be more techie about a solution if I can.
    edited December 2018
    to have a planar faces of your faceted surface you must define your cone as loft surface from a linearized profile to the vertex, and then split the desired shape from the lofted surface
  • lanalana Onshape Employees Posts: 757 image
    Here I've implemented Konstantin's recommendation
    Lana and Konstantin,
    Thank you so much for that advice and your example. That's extremely helpful. I love this forum. I usually post when I'm pretty sure I'm defeated. Someone seems to always come to the rescue.
    Thanks again,
    Kent
    You can also use this faceted loft feature I made:
    https://cad.onshape.com/documents/896f030ae2c1ef8df7e07d34
    IR for AS/NZS 1100
