Sheet Metal corner question
Hey all, I'm just getting into some sheet metal design in Onshape. Well, it's actually not for sheet metal... I'm designing for cardboard and coroplast. Occasionally I design and create cardboard boxes and other shapes that I want to lay flat and cut with my dragknife and crease tool:
https://www.donektools.com/
https://www.donektools.com/product/creasing-attachment/
The way Onshape lays out sheet metal is awesome for this. I can use the bend lines to runt he crease tool, and cut on the outlines of my sheet metal drawing. I'm running into one small snag though, when I do a flange I'm getting these little jogs on the corners:
No matter what settings I use in sheet metal I can't seem to tease these out. I can get them smaller if I turn down the bend radius, but I can never actually remove them. I assume they're for something related to welding or other sheet metal fab stuff, but for my particular application I don't need them. Not only do I not need them, but with those little jogs it can cause the machine to pick up the blade unnecessarily when cutting. Can these be removed?
    @eric_schimelpfenig
    Can you post the link to your document here? (Instructions here)
    Happy to take a look at whether there is a workaround.
