Adding of midpoint lines to sketch tools
This is something I actually pushed for and it got added to SW2015 which made me quite happy. I like to use symmetry a lot, and would find it very helpful to have a mid point line option. Essentially start at a sketch point and the line will be drawn out for the start point symmetrically. (think center-point slot in SW without the third click). I also really like the center-point rectangle they implemented with the orthogonal construction geometry.
I would love to see these implemented to the sketch tools, and imagine it shouldn't be a massive endeavor to do that?
Also is this the section to mention these enhancements, or should this be in the using onshape forum?
1. Start with a point
2. Start mid-point line
3. Draw in any direction and end result is a line with a mid-point constraint to the point
As in this picture?
TVP, Onshape R&D
I saw the rectangle, and what you guys have would probably work, but I meant it would also come with orthogonal construction lines for easier adding of relations. The one that's in the new SW I find quite useful because it just makes it easier to create relations and symmetry. See pic.
TVP, Onshape R&D
Step 1:- Draw a line
Step 2:- Place point exactly midline by draging (Automatically midpoint option will appear for constraining)
Please refer below video for more detail.
