Can a named view be setup in an assembly that can be used accross all documents?
tristan_flintoff
Member Posts: 12 PRO
in Drawings
Is it possible to setup a named view that is a template that can be used across all of my documents in Onshape?
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
Yes! Very easy
Method 1) Set up a new blank document with the views you want. Whenever starting a new document, just copy the workspace of this one - the assembly element will now have the named views. This is akin to building a 'template'.
Method 2) Set up the 'template' as before and 'copy to clipboard' the assembly element. Now whenever you want to create an assembly in a new document, click on the '+' in the bottom left hand corner and select 'paste tab' - boom!
These are two very easy ways to get what you want
Philip Thomas - Onshape3
Thanks........works well
