Can a named view be setup in an assembly that can be used accross all documents?
tristan_flintofftristan_flintoff Member Posts: 12 PRO
Is it possible to setup a named view that is a template that can be used across all of my documents in Onshape?
    Yes! Very easy :)
    Method 1) Set up a new blank document with the views you want. Whenever starting a new document, just copy the workspace of this one - the assembly element will now have the named views. This is akin to building a 'template'.
    Method 2) Set up the 'template' as before and 'copy to clipboard' the assembly element. Now whenever you want to create an assembly in a new document, click on the '+' in the bottom left hand corner and select 'paste tab' - boom!
    These are two very easy ways to get what you want :)
    Philip Thomas - Onshape
    Yes! Very easy :)
  • tristan_flintofftristan_flintoff Member Posts: 12 PRO
    @philip_thomas
    Thanks........works well
