View normal to, Android
famadorianfamadorian Member Posts: 390 ✭✭✭
This view normal to,, is that not available in Android ?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,028 PRO
    select a plane or surface you want to view normal to, then with two fingers, tap into white space to bring up the context menu.
    it will be on the bottom
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    Ah, missed that;) I'm using a stylus. There's no other way to bring forth that menu?
    I dont think so.
    The stylus I use is the one with the galaxy note. I know it doesn't
