Unwanted linking of version/history tree between duplicated part studios
Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 73 PRO
I duplicated a part studio and now when I change the version/history tree of one, it creates an equal change to the version/history tree of the other, even if the parts in the two part studios are now different. I really do not want this; it makes the duplicate part studio feature unusable to me. Is there any way to avoid the linking of version/history trees?
    Please share a link
    IR for AS/NZS 1100
    Are you saying you want Part Studio 1 to be a different Version than Part Studio 2? Versions are for the entire document so every element in a doc will always be the same Version. Physical changes do not propagate between duplicated Part Studios unless you used the Derive feature? To avoid them having the same Version number (which is nothing more than a bookmark in the document history), paste the duplicate tab into a new document.
  • Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 73 PRO
    @NeilCooke
    Yes, I was hoping to have part studios in the same document with different version/history trees. From what you're saying, it sounds like that's not possible. And to answer your question, physical changes were not propagating between my duplicated part studios, but changes to the version/history tree were. Thanks for your reply.
    edited January 2019
    @cedric_eveleigh392
    Just to confirm, History is at the document level.  If you want to explore different design iterations for that Part Studio, consider making a version, and then branching into two or more different branches to represent different designs.  Then you can merge back the one that ends up being the best.
