Extrude Fails
famadorian
Member Posts: 390 ✭✭✭
I was on a roll, creating lots of lofts and then extruding them, then suddenly it wouldn't work on one and it just throws the normal non-intuitive "can't regenerate" message.
Is there any way to get more sensical error messages so that I can figure out what's wrong?;)
Here's the public document:
https://cad.onshape.com/documents/70d70cf1b954c030847ece24/v/569d1fc66d020cf1308e7410/e/d8b4ad7ea70fdf1769c91ad4
If you look at the vertices (and their resultant unit vectors), the loft doesn't create a planar surface:famadorian said:
The loft is between two straight curves, so the face must be planar? Also, why doesn't the error tell me it's not planar, if that's the problem?MBartlett21 said:@famadorian
The face may not be quite planar.
Pease try this FS, which supports non-planar faces:
https://cad.onshape.com/documents/24819ddab7dc83c810eb8246
You may have to specify a direction using two points or a directional face
Also, not sure what you mean with FS? I looked at your document, but it doesn't use a FS function?;)
vertices:v1 = [-835.72000, 6578.46498, -1243.00003]v2 = [-835.72000, -2009.53507, -1243.00003]v3 = [-835.72000, 6578.46498, -4668.00022]v4 = [-835.70999, -2009.53507, -4668.00022]
line vectors:l1 = (v2 - v1) =[0, 1, 0]l2 = (v4 - v3) = [-1.16558×10^-6, 1, 0]
Going from l1 to l2 will require a twist, which makes the resulting surface not planar.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1
That is weird.
But Thicken does work, and is probably more appropriate for what you are doing anyway0 -
@famadorian
You may have to specify a direction using two points or a directional face0 -
@famadorian
It does not tell you it isn't planar. It just doesnt accept the selection.
The faces and sketch regions to extrude box in your extrude is empty.
My document has a FS feature that you can add to your toolbar called Extrude
It allows you to specify a direction and also do a thin-feature extrude0 -
Going from l1 to l2 will require a twist, which makes the resulting surface not planar.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
Really, all the lofts and extrudes are overkill
just extrude your surfaces, then thicken
https://cad.onshape.com/documents/d42e6f41dfe15f73214cc08f/w/9f4e16f982213c9119a76ed0/e/85c5608385533392b45428ce
Turn 50 features into 2
Thicken it is;) Thank youjohn_mcclary said:That is weird.
Ah, it's a FeatureScript called Extrude in there;) Got it; thanks.MBartlett21 said:@famadorian
