Named entities in sketch
When showing/editing  constraints inside sketch quite often the lines overlap, and it's hard to tell/select which one is needed.
Same when using sketch lines in features.
If I were able to name lines, points in sketch, and then reference them by name -- it would be much easier.
    @glib_kotelnytskyy Do you have an example of how you would use this?  In cases like selection, have you used select other?
