Drawing of sheet metal with PEMs
dan_schwartzdan_schwartz Member Posts: 16 ✭✭
Hello
I have assembly of sheet metals with PEMs.
All the parts are in one Part Studio.
Can I make drawing of each sheet metal part with it's PEMs for production?
Dan
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    Hi @dan_schwartz - the PEMs are in the assembly so you will have to create a drawing of the assembly. If you can, move each sheet metal part with PEMs into its own subassembly (which it is in reality). If you can't do that, you can use Display States to hide everything else and create a drawing of the whole assembly.
