Insert Part Studio with configuration into Assembly
dick_van_der_vaart
Member Posts: 51 PRO
I have a Part Studio with a configuration, now I want to insert this Part Studio into a Assembly complete with it's configuration.
Is there a quick way doing this? Copying the configuration or something?
After inserting this Part Studio I want to add more part's from other Part Studio's and configure that.
Thanks in advance
Thanks in advance
I think your best bet is to copy the table into an external spreadsheet and then copy and paste from there for each Part Studio. Again, this will not work if your configurations are changing selections, only numbers.Senior Director, Technical Services, EMEA5
Hi @dick_van_der_vaart when you say “with its configuration” do you mean you want the assembly configuration to have the same entries? You have to create a configuration in the assembly then configure the configuration of the part(s). You can try to copy the table (3 dot menu in configuration tab and Ctrl+V) but it may not work because your inputs may not be the same.Senior Director, Technical Services, EMEA0
@NeilCooke I tried the copy- paste, that doesn't work, and yes I want the assembly to have the same entries.
I don't want to have to many features in one Part Studio, so I want make my other configurations in another Part Studio0 -
