Plastic Design Features
sean_blanchard
Member, User Group Leader Posts: 49 ✭✭✭
I would love to see Onshape implement some plastic design features (Snapfits, grooves, etc.). Anything to assist with the design of plastic components.
5
IR for AS/NZS 1100
HWM-Water Ltd
https://cad.onshape.com/documents/2972a375d9fd3b741d7cc02a/w/45408693c3984999d8c8ff22/e/403280a8c811319478bddf50
I can't for the life me get this to work...
aicher@battleaxe.com
Tigard, OR
One thing to note is that right now it only allows you to select the center points of a circle from a sketch. I need to update it to allow you to select just a plain point or a line vertex when I have time.
Does the script show an error for you? If so, what does it say?
Occasionally, I have seen the ribs cause an error when they connect to a side wall, but if you turn off the ribs it will work. I haven't quite figured out the cause of that one since it doesn't happen all of time.
Works great!
Tigard, OR
I figured out what I was doing wrong for the selection filter, so I just updated it (Version V9). That will allow you to now use a plain point or the vertex of a line for the origin of the mounting boss.
