Implicit mate connectors in custom features
kevin_o_toole_1
By now you might have seen the Improvements to Onshape - March 1st, 2019 post, which mentions, among other things, a new ability to mate connectors on the fly inside a feature dialog:
I thought I would also mention to the FeatureScript forum that this new functionality works just as well in custom features!
For example, the @maximilian_schommer 's recent LaserIt feature has a "reference frame" parameter. His feature code hasn't changed, but as of today, that same feature now allows you to select/edit the mate connector on the fly, without creating a separate Mate Connector feature:
Since LaserIt's "Reference frame" only allows mate connectors, the mate connector selection mode is always on:
annotation { "Name" : "Reference Frame", "Filter" : BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
definition.referenceFrame is Query;
Another recent example is @MBartlett21 's improvements to @Jake_Rosenfeld 's Calculate bounds feature:
Notably, the feature's "Reorient X-axis" option is no longer necessary! The user now has full control of that axis by directly editing the implicit mate connector itself. This means it's now much easier to write any custom features like this, since a single query parameter can provide the full interface necessary to control every aspect of that coordinate system.
And since the "Mate connector or face for coordinate system" parameter also allows selecting things other than mate connectors, this parameter has a "Select mate connectors" button you can press to stop selecting geometry and start inferring mate connectors on that geometry:
annotation { "Name" : "Mate connector or face for coordinate system", "Filter" : BodyType.MATE_CONNECTOR || GeometryType.PLANE, "MaxNumberOfPicks" : 1 }
definition.mateConnector is Query;
The "Select mate connectors" button will be added to any query parameter allowing BodyType.MATE_CONNECTOR, QueryCompoundFilter.ALLOWS_AXIS, or QueryCompoundFilter.ALLOWS_POINT. It works just as well for single selections and for multiple. If you want to disable this functionality, you can add the new UIHint.PREVENT_CREATING_NEW_MATE_CONNECTORS to your query parameter.
Happy FeatureScripting!
  • owen_sparks
    That's all rather good. Thank you.
    Why do you have to release updates on a Friday? This is work so I have to resist playing with it over the weekend... 😀
    Cheers, Owen.
    HWM-Water Ltd
  • MBartlett21
    @kevin_o_toole_1
    @owen_sparks
    I have just released an update to the Calculate Bounds feature that allows it to calculate the minimum bounds of 3d parts.
    I have also changed the UI a lot (with help from @Jake_Rosenfeld )
    You can no longer select faces to use as coordinate systems.
    IR for AS/NZS 1100
  • owen_sparks
    Would it be worth pinning this topic for a while?
    O.S.
    HWM-Water Ltd
  • kevin_o_toole_1
    I just pinned to the top of the FeatureScript category, that should be good enough :smile:
  • owen_sparks
    Thanks. O.S.
    HWM-Water Ltd
  • MBartlett21
    @owen_sparks
    If you keep on commenting on it, it will stay up the top, even without pinning :)
    IR for AS/NZS 1100
  • owen_sparks
    That
    HWM-Water Ltd
  • owen_sparks
    Seems
    HWM-Water Ltd
  • owen_sparks
    Like a lot of work
    HWM-Water Ltd
