duct segmented elbows
digitalcarbon
Member Posts: 102 PRO
someone sent me how they did it in solidworks and wanted to know if the formula method is available in onshape
All 3 center segments are equal to each other.
the end two segments are equal to each other and perpendicular to the horizontal and vertical lines respectively.
Then just add a radius dimension, works with any angle.
Owen S.
HWM-Water Ltd
