Seeing Red Lines Shelling
minesh_govenji
Member Posts: 2 ✭
This is my very first project using onShape. Please excuse any incorrect usage of industry language or terms.
I am seeing red lines on part/ shapes when I try shell out my model.
I am trying to shell this shape:
But I see these red lines when I click on shell:
Any help with issue will be helpful. Thanks!
Onshape, Inc.
https://cad.onshape.com/documents/dfeba83782c4273e64037188/w/9bc87bd799e7a9c64098b030/e/e68e881a0ca822bda146ba1e
The Variable numLobes works from 3 to n (not sure what the upper limit is).
@minesh_govenji your geometry, specifically this:
You see those double edges in the center of the image?, that won't work. Shelling isn't magic and requires clean geometry.
To figure out which faces are violating a shell, offset the faces and when offset stops working, that's your problem. Shell offsets the faces 1st. If you can't offset them, it won't be able to either.
