Mirrored sketch entity not updating
I have a feature mirror that mirrors multiple sketches. These sketches have variable driven geometry. However when I update the variables the original sketches update but not the mirrored sketches. How can I fix this its currently a huge problem for me.
  • christopher_starke
    christopher_starke Member Posts: 9 EDU
    Is there perhaps a way to force the document to completely rebuild from scratch?
    Damn, my sketch has a ton of external references so I suppose that is the problem. I will try reworking the document with no external references.
    Just for clarity do you mean that other sketches reference the sketch or that the sketch references other sketches?
    I delete the references and it works fine which isnt ideal but will work for now. Thank so much for the help!
    NeilCooke Moderator, Onshape Employees Posts: 6,078 image
    Another alternative is to use offset surface to “copy” your first sketch, then mirror that.
