precision in millimeter drawing template
tiffany_liutiffany_liu Member Posts: 2 EDU
When I create a drawing using Onshape's ANSI drawing template ANSI_B_MM.dwt and I dimension my part, I cannot set/change the precision of the dimension. For example I can dimension only 5mm and 42.5mm but not 5.00mm or 42.500mm. I noticed this is possible in the inch drawing templates but not in the millimeter templates. Is there a reason for this or am I doing something wrong?
Thanks!
    Take a look in the properties dialog (wrench icon on the right) - you can set decimal points and trailing zeroes there.
