I have a "named position" in an assembly model which I would like to display as a view on a drawing
john_croninjohn_cronin Member Posts: 2
sheet. Is that possible?
    You can, but as soon as you change it to another named position, the drawing will see it as out of date. All the views on the drawing will also have to use the same named position.
    You have 2 options - create your drawing and version it when done, so that it never changes, or use assembly configs to hold the position of the mate and make views of that. If you are wanting to superimpose 2 views in different positions over the top of each other then that is not possible (unless you use configs and manually position the views on top of each other).
