Download Source File
famadorianfamadorian Member Posts: 390 ✭✭✭
I have imported a DXF into Onshape which I then shared with a public link.
However, the recipient can't download the DXF.
This defeats the purpose.
I also had the same problem with AutoCAD Online Viewer.
What is the reason for this?
That means I have to send DXF files. Wasn't the whole point that I didn't have to deal with files?
Is there any way to let the recipient be able to download the DXF?;)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,925 image
    edited April 2019
    Right click the DXF tab at the bottom of the screen and select Download.
    Or press the download button on the view-only UI (big buttons along the bottom of the screen when a doc is view-only).
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    You can see a big download button on this screen?;)
    I was thinking about regular parts and assemblies. The download for DXF tabs can be found here:
    Did you find it?
    Did you find it?
    No, it only presents a "open in new tab" when right clicking it.
    Here's the link to the document:
    https://cad.onshape.com/documents/b8f7c870f220075429034dce/w/d21572d69bae96f1860534d3/e/c128cd0cf9e84710f6c0b333
    Ah ok, wait a minute - you used link sharing? You only need to copy paste the URL from the browser. Link sharing prohibits download:
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
    Did you allow exporting when you shared it with a link?
    IR for AS/NZS 1100
    No, it seems link sharing is ok, as long as I activate "export";)
    That was the solution;) Thanks.
