Populate BOM description with name if empty
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
I would like the Description column in the BOM to populate with the Part Name if the description has not been set.
IR for AS/NZS 1100
    @MBartlett21 This request is an automation that does not fit all parties.  I would say if you are looking to do this type of automation you would need to use the API.  In most cases this can be addressed with BOM templates so you can show what columns you want everytime.
    Ok. I'll try something with the API
    IR for AS/NZS 1100
