Show Mate Connectors
famadorian
Member Posts: 390 ✭✭✭
There's a "show mate" here, but not a "show mate connectors". To view the mate connectors, I have to "show all", but that shows all the stuff I've hidden;)
Is there a way to just show the mate connectors?
I need it when I click "create part studio in context"
And don't forget the keyboard shortcut "K" (shows / hides all MCs) and "J" (shows / hides all mates).
You can pretty quickly cycle through the visibility states for Mate Connectors, select the one you want, then hide them again.5
also, instead of a long context menu, isn't something like an advanced context menu, like Maya has with multiple directions and levels, something to look at?0
you can right click the part, then click "go to item in list"
from there you can click the expander and see all of the mate connectors, you can hide/show them from here individually too.
for better menus check this improvement request out
https://forum.onshape.com/discussion/comment/51444#Comment_51444
3 -
You can pretty quickly cycle through the visibility states for Mate Connectors, select the one you want, then hide them again.5 -
Ah, it's a toggle;)romeograham said:And don't forget the keyboard shortcut "K" (shows / hides all MCs) and "J" (shows / hides all mates).
Thanks1
