Tambour front box (aka roller door)
connor_macmurray
connor_macmurray Posts: 11 EDU
edited May 2019 in Community Support
I am attempting to make a tambour front box, like a bread box, only smaller and with a bottom drawer that the roller door section connects to. When you pull out the drawer, the roller door opens, when you close the drawer, the roller door closes.
The tambour/roller door is made up in real life from timber slats 6mm thick, 10mm wide and 220mm long. They run in a groove that is 6.5mm wide and are connected together by laying them out flat and gluing canvas to the underside which provides the articulation. In order to replicate this in Onshape I made a revolute mate between the lower edges that touched therefore allowing the tambour to in theory bend around the groove in the sides.
In real life the tambour is inserted into the grrove at the bottom and fed up and around. Then the tail end is screwed into the bottom of the drawer which means when the drawer is opened it then gets pulled along the groove underneath and therefore retracts the tambour on top.
Here is the view from the other side
Also, the reason why it looks so funny is that I tried to move them upward in one go but the middle two decided not to move and so the others flexed accordingly showing the revolute mate obviously works.
I have only been using Onshape for a day, but have used other CAD packages before, but this is killing me. I've tried pin and slot, which I now know is the wrong thing, and tangent but it doesn't seem to want to work either.
Any help with this would be greatly appreciated.
Connor
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    When making paths with tangent mates and slots, it is sometimes best to thicken one wall of the slot and use it as a mate surface.
    otherwise the tangent path will attempt to wrap around the radius at the end of the slot and travel up the back side of the slot.
    from there add a tangent mate to the leading corner of each part to the highlighted face i show here.
    then you can hid your path part and all should be well
