Exploded View Drawing
matthew_khourymatthew_khoury Member Posts: 1 PRO
Hi,
I cannot figure out how to create a proper exploded view drawings with dashed lines indicating the assembly patterns. Any help?
Here's an example of a drawing I did in SolidWorks:
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,005 PRO
    You will need to explode it manually,
    one way may be to suppress all mates, then drag your parts out.
    Then create a saved position
    Then you can insert that saved position into a drawing and use center lines to connect holes.
    you could also create an in-context of that position and create sketches is a part studio to connect the holes, then insert the sketches into the drawing
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    We have pushed an update that adds exploded view functionality: https://www.onshape.com/cad-blog/introducing-exploded-views-in-onshape
    Twitter: @bradleysauln
