How to add fillets on a sketch while designing walls (so, a fillet and then another fillet inside).
bruno_verachten
Member Posts: 17 ✭
Hi,
I'm pretty new to all this CAD, so please bear with me.
I am designing a box and added fillets to a bulgy part, so that it does not look that ugly.
This box has walls, so I'd like to keep the fillet for the walls too, now that I have one for the base.
How should I do to replicate the fillets I chose for the base for the outside and inside face of the wall?
Thanks.
Thanks.
NeilCooke
Moderator, Onshape Employees Posts: 6,035
Create the box as a solid block (you can add the fillets on later as a fillet feature which is recommended), then use the shell feature to hollow it out to make the walls with the correct internal fillets.Senior Director, Technical Services, EMEA7
