Feature Script Parameter Bounds driven by another Parameter
bill_schnoebelenbill_schnoebelen OS Professional, Developers, User Group Leader, csevp Posts: 131 PRO
edited June 2019 in General
I am trying to bound a parameter based on the input to another parameter.
For the code below. I want to always make sure Y is less than or equal to X. In another case, I would want Y to be 1/3 X. Is this possible?
If not, is there a TextBox.Change event where I can test? :)
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    You can test in the feature body itself, something like:
    if (definition.y > definition.x)
        throw regenError("y must not be greater than x", ["y"]);
    (passing the parameter y in the second argument to regenError will make it highlight in red if it's out of focus)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    edited June 2019
    You can also do this using Editing Logic if you want the field to change dynamically. See the Spur Gear for an example.
  • bill_schnoebelenbill_schnoebelen OS Professional, Developers, User Group Leader, csevp Posts: 131 PRO
    Thanks guys. I think either of those will work. I am going to use the first one for now since it is simpler.
