Sheet Metal Truncated Pyramid
john_doubledayjohn_doubleday Member Posts: 58 ✭✭
Trying to sketch a sheet metal  Laptop Stand. It has angles in both direction, (compound.angle) like a truncated Pyramid Just wondering the best way to go around this exercise.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Probably easiest to model it as a solid block then use the sheet metal convert tool to select the faces and bend edges to get the outside shape. Then add other details like flanges and holes.
  • john_doubledayjohn_doubleday Member Posts: 58 ✭✭
    Thanks Neil. As a quick work round I have taken out one of the angles.....makes it a lot easier (so now just a  right angle).....I think it going to work:)) and a nice little update on sheet metal for high school:))
