Making a Part Studio sketch visible in Assembly
POCPOC Member Posts: 26 PRO
Hello
Is it possible to enable a part studio sketch to be seen in the Assembly?  (as a visual aid not to appear in a drawing ect...) Thanks
  • POCPOC Member Posts: 26 PRO
    Thank you Mike,
    I've followed the procedure, when I insert the sketch from the part studio I constrain it so it matches its location within the PS solid.. so 2 stage process to achieve the desired result? inquiring in case I'm missing a trick!!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    @POC that is correct - when inserting anything into an assembly, it is free to move unless you constrain it somehow.
