how do i move and edge in onshape?
david_minforddavid_minford Member Posts: 2
Im using 123d design and i cant figure out how to move and edge in onshape could someone help?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,983 image
    Native Onshape models have parametric sketches and features, so all you need to do is edit the numbers. If you want to modify imported geometry, see the Move Face command and other Direct Editing features.
