select the axis to revolve around
darren_mason871
Member Posts: 44 ✭✭
I've made a shape that I'm trying to revolve, but I don't know how to select the axis to revolve around.
Hi.That depends on your end goal?Here are two of a bunch of possible revolves of your original sketch:-
A straight edge, circle and z-axis of a mate connector are all valid inputs for a revolve axis.On the left example I've used the centre vertical axis, on the right example I've used the top edge of the sketch. Note on the left example the sketch needs to be split into two regions. You just want one half to revolve otherwise one side intersects the other on a full revolve.Example doc here:-Help docs:-Does that help?Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd1 -
You can learn all about revolve features here: https://cad.onshape.com/help/Content/revolve.htm or here: https://learn.onshape.com
Senior Director, Technical Services, EMEA1
