Piano Hinge tool?
digitalcarbon
Member Posts: 102 PRO
in General
Anything?
https://cad.onshape.com/documents/8521bd539dfb26353d20f48c/w/ff52ca5a0d2761d21ed2ecd4/e/d47a8b730a1003d5ba823edd
Twitter: @BryanLAGdesign
I don’t know anything about the below company, but they look like a pretty good resource for CAD files
I was able to import the file into Onshape, and after doing a split around the pin, you could see how I was able to animate it
Here is the file I imported —
https://cad.onshape.com/documents/3c5fc597ce14ae7ea9c04810/w/17b633c11bee90b2f8b79b35/e/45ac7279115939b8eda40e9e
In the future, hopefully soon, we'll be able to post OS models on the web. When this happens, you'll be able to drive the design with configurations and a vendor could easily provide variants of their product. You'll be able to use the hinge in your design.
When this happens, the world of design as we know it, will change.
It's not that far off.
You could use a configuration variable to set the length of the usable hinge and then use the Set property custom feature to set that variable to a custom company property. I believe @MBartlett21 wrote the custom feature.
Onshape, Inc.
