Feature Control Frame attached to hole dimension?
brian_bradybrian_brady Member, Developers Posts: 505 EDU
The title basically says it all. Can a feature control frame be added to a hole dimension so that if the dimension is moved the frame follows? I know they can be attached to other dimensions, I just cannot get it to work with a hole dimension.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 567 image
    @brian_brady Currently no, GDT frames can't be automatically grouped to hole callouts - but it's on the list of things to deliver.
  • brian_bradybrian_brady Member, Developers Posts: 505 EDU
    I will wait with great anticipation.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,029 PRO
    .. Resists urge to ... time .. warp .
