Can sweeps be made with lofts?
out of curiosity.
A loft with 2 same profiles and a path look a lot like the sweep function.
Is it basically the same and is the sweep feature nice UX, or are there fundamental advantages to use a sweep instead of loft besides easy acces.
If it is the same thing, it migh be interesting to integrate the sweep inside the loft. Making a loft but only selecting 1 profile and a path, similar as sweep.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,624
Sweep also guarantees that the cross section of the created part along the given path is constant. Loft does not make this guarantee, and can be very different based on the options selected in the feature.Jake Rosenfeld - Modeling Team5
