Featurescript - Creating cylinder in context
Hugh_Goodbody
Hugh_Goodbody Member Posts: 41 PRO
I am writing a featurescript to create a cylinder between two points (usually the centres of two circles). Currently I can create the cylinder between two vertices or mate connectors in a part studio, and this is all good.
I would also like this to work in context but doing it this way, I can only select the edges of circles. I have added the circle selection to the UI:
annotation { "Name" : "Start Point", "Filter" : EntityType.VERTEX || BodyType.MATE_CONNECTOR || (GeometryType.CIRCLE), "MaxNumberOfPicks" : 1 }
        definition.startVertex is Query;
So the result of the above is that I either have a vertext point, or a circle.
So my question is: Is the best way to resolve this by incorporating an IF statement, ie IF the user selects a circle, then evaluate the centre point and use this as the vertex? or is there a better way?
The second part to the question, is how do I test if the circle has been selected?
Thanks in advance!
    NeilCooke Moderator, Onshape Employees Posts: 6,106 image
    Put evCurveDefinition in a try block to test for a circle (which will fail if it is not a curve)
        precondition
            var startVertex;
            try silent
                startVertex = evCurveDefinition(context, {
                                "edge" : definition.startVertex }).coordSystem.origin;
            catch
                startVertex = evVertexPoint(context, { "vertex" : definition.startVertex });
            println(startVertex);
  • Jake_Rosenfeld
    edited August 2019
    Just to encourage good FS practices, the way we would do this for an official feature is as follows:
    precondition
        annotation { ... }
        definition.start is Query;
        // Check if the user has supplied a query, or has left the box blank
        if (size(evaluateQuery(context, definition.start)) != 1)
            // Arguments here are the error that will displayed if the user hovers over the feature, and the name of the
            // selection box that should be turned red.  Note that it only turns red if a different box is focused; when it
            // is focused, it will always be blue.
            throw regenError("Select start point", ["start"]);
        // Assuming that selecting a point is more common, you would want to check for that first to not waste compute cycles.
        // The `try silent(...)` and `try(...)` expressions return what is evaluated inside them if there is no error thrown, or
        // return `undefined` if an error is thrown inside them.
        var startPosition = try silent(evVertexPoint(context, { "vertex" : definition.start }));
        if (startPosition == undefined)
            startPosition = try silent(evCurveDefinition(context, { "edge" : definition.start }).coordSystem.origin);
            // If both checks failed, throw a useful error.  In addition to the parameters described above, I am also passing
            // definition.start as an error entity. This entity will be highlighted in red to show the user what is wrong.
            throw regenError("Start point should be a vertex, a mate connector, or a circular edge", ["start"], definition.start);
    Some info on all this try and try silent stuff:
    https://cad.onshape.com/FsDoc/exceptions.html
    Another tip for this: once you find the two positions that you care about, `fCylinder` is going to be your best friend.  It does exactly what you want (take two points and a radius and make a cylinder between them):
    https://cad.onshape.com/FsDoc/library.html#fCylinder-Context-Id-map
  • Hugh_Goodbody
    Thanks Jake, will endeavour to incorporate!
