Importing an image into an assembly
IT_RobotiqIT_Robotiq Member Posts: 2 PRO
Hi,
I've seen a discussion in 2016 about the fact that it was possible to import an image into a Part Studio by using the sketch tool, but that when we wanted to import this sketch into an assembly, the image would have disappeared.
I was wondering if this was a resolved issue, because right now I'm not able to put an image into an assembly.
Thank you.
    Sorry, this capability is not available yet. Can you please vote on the improvement request or raise a support ticket to that effect?
  • sabine_fuchssabine_fuchs Member Posts: 1 PRO
    Hi,
    is there a solution for this in the meantime?
    Thanks for help!
