Import a DWF file?
Michael_CoffeeMichael_Coffee Member Posts: 91 ✭✭✭
At the moment, importing .dwf files is not supported. Has anyone found a work-around if another CAD program isn't available to you? I would normally import either a .step or .iges, and I thought .dwf would be supported, but apparently not.
    DWF is a viewing format and I don’t think any software can import it without some prior conversion to DWG?
