How to remove a "round" corner
kai_h_borbekai_h_borbe Member Posts: 14 EDU
Hey Froum,
i need your help, at my project. I want to remove material in a round corner.
At the screenshots below, you csan see the hole situation.
To cut the material, i made a sketch:
Sketch
Front-view
oblique view
from underneath-view
I tried a view things, with extrude and rotate, but it dosent work.
For example, if i choose extrude the sketch and the the edge of the corner in the front:
modern-art ? :o
How can i, remove the superfluous material ?
Best regards
Kai
    Presumably you’ve tried the fillet command? If that doesn’t produce what you want you will have to do some fancy surface loft and split.
    Could you use a loft between a lower triangular sketch and an upper vertex and then boolean that away from your solid?
    Owen S.
    HWM-Water Ltd
  • kai_h_borbekai_h_borbe Member Posts: 14 EDU
    thank you for your advice, your tip was good !
    I solved it, like this, but im not 100% statisfied, i will look into it tomorrow.
    Best regards
    Kai
    Nice :+1:  Looks like you are nearly there.
    Owen S.
    HWM-Water Ltd
