Cannot load drawing and cannot report a bug
hristo_goumnerov
Member Posts: 4 ✭
Dear All,
I have tried creating several documents and then a corresponding drawing, but the drawing never loads. In some cases i can see a thumbnail of the drawing when i hover over the tab with my cursor, but that's about it. When i try to report a bug nothing happens, while all the other functions work. Please help.
This is one of the documents: https://cad.onshape.com/documents/f4c4b662c7b900c1cfa87ab2/w/3f22da05799a59c9bf3fa3d9/e/84ed1d9a3b4d8e80a7ba6c12
Thank you for your help in advance.
Hi @hristo_goumnerov, are you in an environment where hosts or ports are blocked going outbound?John Rousseau / VP, Technical Operations / Onshape Inc.0
Hello John,Thanks for the quick reply. I'm accessing the internet via a company proxy/firewall so it may be the case that some ports are blocked. However, i have tried loading a drawing for the same document from my home computer and had the same issue.0
I just opened the drawing on your document without any issues. Do you have any errors in your browser console?John Rousseau / VP, Technical Operations / Onshape Inc.0
For what it's worth the drawing in the link above opened in just a second or two for me.Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
When i load the document/drawing i get the warnings and error in the attached image.
@hristo_goumnerov
What browser are you using?0 -
Hello again, I'm using Firefox. When i do the system check, everything is fine and i get green checkmarks.
Do you have any browser add-ins/extensions running like Ad blockers? Try disabling those. Also in the console error you posted above, what does it say in the SecurityError if you expand it (click the red arrow)?Senior Director, Technical Services, EMEA0
