A way of making a surface out of a part?
Given a solid part, can I take the outer areas to make a surface?
  • terry_pipkinterry_pipkin Member Posts: 48 PRO
    Offset surface at zero thickness?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,989 image
    edited September 2019
    Delete Face / Leave Open will remove faces to make a surface. If you want an enclosed surface (not sure why?) you can close the open face using Fill
