Configuration Horizontal Scroll
  • Configuration Horizontal Scroll - Currently, the horizontal scroll bar for the configuration panel is at the bottom of the configured rows. This means that you have to scroll all the way down before you can scroll right or left. This improvement will keep the horizontal scroll bar "always in front" or floating, similar to the column titles.
    @cache_river_millworks This is a bug.  I will pull a ticket for you.
  • oliver_augustoliver_august Member, pcbaevp Posts: 30 PRO
    edited June 2025
    I´m a little bit astonished that almost no one seems to be upset about this.
    This bug really SUCKS.
    I´m not working with OS for six years as the TO, but this one ist a pain to me all the time - it tears me out of concentration on what I have to do over and over again.
    An absolutely unnecessary waste of time
    The bug is obviously known for six years now - and nothing happened to fix it… to me it´s annoying time and time again.
  • JackTervayJackTervay Member Posts: 2 PRO
    @oliver_august I hear your frustration. As it currently stands, would using the shift+scroll shortcut to horizontally scroll through the configuration table fix this issue for you? This is how I navigate the configuration table and how I used to navigate the BOM until they added a persisting horizontal scrollbar in their latest improvements. Offering this as a suggestion as it seems a lot of people aren't aware of this keyboard shortcut! The attached gif is showing the behavior of using shift+scroll on Mac.
