What does Fixing a Table Corner Actually Do?
S_Regula
S_Regula Member Posts: 95 PRO
I have a table on my drawing with the lower right corner fixed (black dot in first picture), and the lower right corner docked to the lower left corner of my title block. When I add a column, the table gets pushed to the right into my title block. Since I fixed the lower right corner, it would make sense for the table to stay fixed at that corner, and "push" the table to the left. Why does it do this? What does "fixing" a corner of a table actually do?
  • brian_brady
    brian_brady Member, Developers Posts: 505 EDU
    I have fixed a corner of a table in the past (two months ago) and when changing a column width or some other change the fixed corner moved. This has happened multiple times. Maybe just an anomaly or a bug. I haven't noticed it recently.
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    edited October 2019
    @brian_brady If you still see it, please "Report a bug" under the help menu and we will take a look.
