How to do a simple rotation of cylinder around center point after a move?
jarrod_bellmore
jarrod_bellmore Member Posts: 3 ✭✭
Hello!
I am pretty new to featurescript (though I am a software engineer in my day job). I have been able to do some of the basics like making a drawing plane, extruding the plane and moving bodies around but I can't seem to figure out how to do a basic rotation of a cylindrical body I have created. This seems like it should be a pretty simple thing to do so I am guessing I must be missing something!
The only example I can find seems to rotate the body around an axis relative to the world, not relative to itself. I basically just want to "spin" the object without having the object change position. Is there an example of this someone could point me towards?
Thank you!
    NeilCooke Moderator, Onshape Employees Posts: 6,113 image
    Take a look at rotationAround which takes a line (the cylinder axis), then use opTransform
  • jarrod_bellmore
    Thanks for the response! I did take a look at that, particularly this forum post:
    https://forum.onshape.com/discussion/3590/transform-rotate-around-axis
    So I guess my question is, how do I get the center line of the object? I tried creating a plan on the top face of the cylinder using evPlane and using the origin/normal to create the line to pass into rotationAround but that does not seem to be doing what I want.
    In the forum post I linked to they show creating the line to rotate around like this:
    const zAxis = line(vector(0, 0, 0) * meter, vector(0, 0, 1));
    Is the line created by this set to 0,0,0 of the world or 0,0,0 of the plane? Using rotationAround I am able to rotate the object it just doesn't seem to be around the center line as the object moves as well as rotates.
    Thanks again!
        precondition
            annotation { "Name" : "Cylinder", "Filter" : EntityType.FACE && GeometryType.CYLINDER, "MaxNumberOfPicks" : 1 }
            definition.cyl is Query;
            annotation { "Name" : "Angle" }
            isAngle(definition.angle, ANGLE_360_BOUNDS);
            var axis = evAxis(context, { "axis" : definition.cyl });
            var angle = rotationAround(axis, definition.angle);
            opTransform(context, id + "rotate", {
                        "bodies" : qOwnerBody(definition.cyl),
                        "transform" : angle });
  • Fda
    Fda Member Posts: 42 ✭✭
    I leave here a complete test of:
    NeilCooke said:
        precondition
    https://cad.onshape.com/documents/c5698e768c34d23543bbe7aa/w/ee5ffbf19da0ae5ae19c4dd0/e/f8faa9dc058fc1731f57c070
