Finding Concave Faces
Manfred_S
Manfred_S Member Posts: 3 EDU
Hello All,
I am just a beginner with featurescript and I am having trouble finding concave connected faces of a solid part, using featurescript. When I tried using the code shown below the debug showed all the faces of the selected solid part not just the concave connected faces.
The aim is to find the concave edges using these faces but there may be an easier way than way I am trying to do it currently. I will also want to find all the convex edges of the part eventually.
Could someone help me out please?
Thanks,
Manfred
Here is the code i was trying to use:
FeatureScript 1188;
import(path : "onshape/std/geometry.fs", version : "1188.0");
export const LENGTH_BOUND =
            (millimeter) : [0, 2.5, 1e10]
        } as LengthBoundSpec;
export const LENGTH_BOUND2 =
annotation { "Feature Type Name" : "Fillet Plus" }
export const myFillet = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Parts to Fillet", "Filter" : EntityType.BODY && BodyType.SOLID, "MaxNumberOfPicks" : 1e10 }
        definition.part is Query;
        annotation { "Name" : "Edges to Exclude", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1e10 }
        definition.edgesExcl is Query;
        annotation { "Name" : "Faces to Exclude", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1e10 }
        definition.facesExcl is Query;
        annotation { "Name" : "Convex Radius" }
        isLength(definition.convexR, LENGTH_BOUND);
        annotation { "Name" : "Concave Radius" }
        isLength(definition.concaveR, LENGTH_BOUND2);
       var allEdges = qOwnedByBody(definition.part, EntityType.EDGE);
        var edgesExclEdge = qSubtraction(allEdges, definition.edgesExcl);
        var faceEdges = qEdgeAdjacent(definition.facesExcl, EntityType.EDGE);
        var edgesExclFaceEdge = qSubtraction(edgesExclEdge, faceEdges);
        var partFaces = qOwnedByBody(definition.part, EntityType.FACE);
        var concaveFaces = qConcaveConnectedFaces(partFaces);
        debug(context, concaveFaces);
    That query takes a seed face (in which case, you selected every face) then searches outwards from there, so that is why everything highlights. You will probably have to loop through each face individually. An example of the geometry you are testing would help.
  • Manfred_S
    Thanks for your help.
    Here is the simple block that I am using to test the script.
    This works. Not sure it's the most efficient solution:
            var faces = qOwnedByBody(definition.body, EntityType.FACE);
            var result = qNothing();
            for(var face in evaluateQuery(context, faces))
                result = qUnion([result, qSubtraction(qConcaveConnectedFaces(face), face)]);
            debug(context, result);
    A solution for both:
            var concaveFaces = qNothing();
            for(var face in evaluateQuery(context, partFaces))
                concaveFaces = qUnion([concaveFaces, qSubtraction(qConcaveConnectedFaces(face), face)]);
            var convexFaces = qSubtraction(partFaces,concaveFaces);
            var convexEdges = qAdjacent(convexFaces, AdjacencyType.EDGE, EntityType.EDGE);
            var concaveEdges = qSubtraction(qOwnedByBody(definition.part, EntityType.EDGE), convexEdges);
  • Manfred_S
    That's good. Thank you very much!
