conditionally reference a variable
EvanReese
EvanReese Member, Mentor Posts: 3,070 PRO
edited December 2019 in FeatureScript
I'm working on a multi-variable feature using an array parameter. I'm looking for a way to optionally reference a variable that's earlier in the array. Here's what I'm trying to do, but it doesn't like it.
I think it doesn't like it because the feature isn't finished until I hit the green check, so it can't see Var1 yet. I believe I can use getVariable() to access it in the featurescript, but I'm stumped on how to make that conditional. I want it to be something like if (Variable contains "#" then grab the variable name and use getVariable(), else, just use the number that's there). I have even less of a clue on how to make that work if I wanted to reference 2 variables at once, like Var3 = #Var1+#Var2.
how can I find any word using a # and convert that to a getVariable function? Or is there a much simpler way?
The code is here if you'd like to see it
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    Just a shot in the dark but.
    Can you create a loop at the beginning of your code that creates a map that has this format: Vars [id, name, value];
    that stores all of the created vars sequentially.
    I'm not sure if you can parse a string in FeatureScript though. But otherwise I'd parse the value of each variable and to a replace #xxxx with whatever Vars[] has a matching "name".
    Vars[2].value = Vars[1].value * 2
    I probably don't have the syntax right, but you see what I'm getting at?
    Then you setVariable(context, Vars[n].name, Vars[n].value); in a loop at the end
  • MBartlett21
    Just if anyone comes across this thread, we ended up getting it to work here:
    https://forum.onshape.com/discussion/comment/58476/#Comment_58476
    IR for AS/NZS 1100
  • EvanReese
    haha, "we". @m@MBartlett21 got it to work and I watched. I do still use that feature in most of my models though!
  • john_mcclary
    Yea, thats about how it goes when he helps me too.  Just get out of the way and watch him go.
